Brand preventie
wellicht dat dan de rode leiding uit de flesaansluiting wordt geperst of de leiding zelf openbarst  :-(
     Re:firetec brandblussysteem
« Antwoord #106 Gepost op: September 01, 2010, 23:49:07 »
nog een nabrander (   ) van firetec:
ik had de vraag gesteld of de brandblussers kunnen bevriezen, dit is het antwoord wat ik kreeg:
" Some details from Firetec. Remember these are ambient temps, so not contact with surface ie exhaust temps.
Reacton R 80 (red) plastic tube: ( Deze krijgen wij)
Max ambient temp: 75 C
Min temp exposure:
with dry powder: - 30C
with just AFFF foam: -10C
with AFFF + Freezol: -20C or lower if customer specifies.
n.b. the plastic tube itself is not damaged by frost. It becomes harder but being plastic can withstand the expansion of water as it turns into ice. When the water inside is frozen solid don’t bend the tube! The aluminium cylinders are not damaged by ice as aluminum is also slightly plastic.
vraag:
So are our systems filled with "standard" foam and is it advised to prevent them from being lower than - 10 c ?
answer:
Yes they are the 'standard' foam, and its advised not to handle them below -10, but no damage is incurred if they do freeze when fitted. And once fitted, when the engine is used, it will increase the engine bay temp's so it would thaw out anyway.
vervolgens een aanbod om voor 5 gbp ex btw antivries toe te voegn voor -20 c
Reply regarding freezing temps.
"The additive is Freezol. This is especially name for AFFF FIRE extinguishers. Freezol itself is inflammable !!! So we have to put in extra AFFF to overcome the Freezol !!!
Net result: add Ł5.00 for T2 size cylinder."
That would be Ł5 plus VAT at 17.5% if anyone wants a custom mix in the bottle.
Als er iemand is die dit extra wil dient men per ommegaande te reageren, morgen voor middeernacht niets gehoord blijft de specificatie zonder antivries (omgereklnd komt het op 7,50 euro extra wat betaald kan worden bij afhalen.)
cheers René
Offline Ron
Mooi, ook weer opgehelderd.
Beetje vorst kunnen ze dus wel hebben, maar beschermen tegen strenge vorst.
En nu maar hopen dat het weer gauw voorjaar wordt  :sunny:
Offline stefan
  • '65 walk through de luxe
Net bericht binnen dat mijn order verwerkt is ,firetec syst. , via mijn werk krijg ik hem straks geleverd.
Dus als de bus er is ,kan ik hem over een maandje inbouwen, keuren ,en met een veiliger gevoel rijden.
Heb hem trouwens zonder antivries additive besteld.
Offline sierk
ben zelf ook op zoek naar een  brandblusser voor in mijn bus in de motorruimte maar weet niet welke de beste keuze is.....
http://www.fireblocker.nl/category/auto
http://www.firebuddy.nl/rally/
de firebuddy werkt met een breekglaasje ....weet niet of dat zo handig is.
iemand een idee? wil het er voor de vakantie in hebben,ga nl met de spijl richting italie in week 29. 8-)
ik zou maar een firetec kopen, ziet er heel wat beter uit!
drukloos oplaten sturen of door iemand mee laten nemen
hoor het wel als je meer wilt weten
Offline sierk
tja een firetec lijkt me zeker oké maar hoe krijg zoiets hier (heb daar geen ervaring mee uit t buitenland kopen)  :-"
zou je me er mee kunnen helpen en hoe lang duurt het voor je zoiets thuis hebt?
Offline Koenraad
De meerkost tov je bus is het waard Sierk, ik ben er reeds te laat mee, maar zou geen tweede keer meer twijfelen.
Hier idem,
Dat hij nu watergekoeld wordt toch dit systeem graag behouden en opnieuw gemonteerd.
Offline sierk
Koenraad, heb jij er inmiddels al een besteld ?
ik zou er graag ook een willen en zou het prettig vinden als iemand die er een besteld er ook een voor mij zou kunnen bestellen  :-"
groet Sierk.
Offline Koenraad
groet Sierk.
Nee, eerst krijgt de bus voorrang, die moet volledig terug afgebouwd worden. En aangezien dit van lange adem zal zijn kan dit wel een jaartje of 2 duren eer ik dit systeem bestel. Na afbouw komt het er zeker in, vooral omdat ik nu bezig ben met de type 4 motor die ik had volledig aan te passen naar een 2.3. Had ik het eerder nodig gehad had ik die moeite voor jou gerust willen doen.
Groeten Koenraad
Offline type3driver
Ik zou hier wel iets meer willen over weten. Waar te kopen? En kunnen ze die dan verzenden? Link misschien?
Had er graag 2 besteld.
http://www.vwjim.co.uk/ourshop/cat_334914-Fire-Suppression-Systems.html
http://www.vwjim.co.uk/news_6694_56042.html
in de balk hierboven bij zoek even   firetec brandblssysteem invullen en je kan de hele topic van de groupbuy lezen met alle informatie die er van is
cheers Renka
Offline type3driver
Lijkt mij hetzelfde principe van de firetec. Ziet er mij degelijk uit! Maar wel een stukje duurder dan de firetec.
http://www.afxfiresolutions.com/site/FA3C8E2F9245E068C12577D000333914
Offline type3driver
Moest je interesse hebben, dan heeft er iemand op flat4free een leverancier gevonden in Nederland van die firetec systemen. Nu is hij nog aan het mailen voor korting voor een groepsaankoop.
Link: http://www.flat4free.be/forum/viewtopic.php?p=763380#763380
